TRACTION CONTROL
notacarlo
Car: 2003 M45, 1986 Mustang SVO
2003 M45
IS THE VDC OVERRIDE ALSO THE TRACTION CONTROL OVERRIDE?
I romped on it last night. Car took off like it was being chased by godzilla then proceeded to almost throw me into the windshield. I forgot to shut down the VDC.
Just curious.
peter_rabbit
Car: 2003 m45 white pearl, '99 mustang gt vert
Yes, but the traction control on these cars don't totally disengage.
DRIPS
Car: 2003 Infiniti M45
I take the VDC off when I want to tear it loose. Works every time! Love power of this machine!!
eggyacid
I have an 06 M35 and VDC is always on.am I correct that VDC is "Vehicle Dynamic Control" it's not traction control, right?do 06 M35 have traction control? or VDC = Traction control?
another lame question, why would someone ever turn off VDC?
digiboy
Car: Infiniti M35x
VDC is different than traction control.
VDC will adjust engine power and/or brake individual wheels to reduce power to prevent understeer or oversteer during emergency maneuvers. This is in response to hard turning of the steering wheel and braking
TCS prevents wheel spin by sensing when one wheel is spinning faster than the rest - loss of traction. It responds by slowing that wheel down to try and get traction on that wheel and not kick the car wildly when traction returns (anti-skid).
If you are tracking a car and you are trying to follow a line - having VDC on will slow down the car even though you are in control. So "on" when driving around and you need to avoid that Prius that stops for no reason in a 45 MPH zone. "off" when you are pushing your car to the limit when Prius free.
eggyacid
cool, thanks...so do 06 model have traction control?
marlin29311
Car: 2008 Infiniti G35x
digiboy wrote:VDC is different than traction control.
Yes and no - the Traction control system is actually a part of the VDC system. The VDC system handles both the TCS (so if you are spinning off the line, the car will still act like TCS) and the VDC (the understeer/oversteer issues).
If you have VDC in your car, then you have TCS. The VDC system supercedes the TCS system. By hitting the button, you are turning them both off (though you can't turn either off completely...)
