SpecDRacing »
https://forums.nicoclub.com/specdracing-u28175.html
Thu May 05, 2005 5:31 pm
I'll give this a shot. LOL Ok, TCS is a complicated system on the infinitis as it has changed almost every 3 years with infiniti and has seen many different versions depending on what year your car is and what model.
TCS works be seeing a differentiation in rotational speeds from several different locations. The ABS system can also input speed signals to the TCS system. Depending on what signals it sees and from what components. These signals are frequencies, using rings that look like gears located either on the differential at the input or output flanges, on the axles at the hubs, inside the differential and/or transmission and also the ring gear of the engine (also used for ignition timing and engine related components). All those signals are then processed and from that, slip is determined. Heres the clinch, slip is only determined when the computer sees that the signals recieved are failing to stay within set perameters predetermined by the programming (newer cars have whats called unified meters, which is the gauge pod on the dash, it houses the control unit now, along with VDC and ABS). Anyway, those sesnors can easily misrepresent reality, causing incorrect information to be processed, giving you your slip light.
Some causes:
-Drastic wheel size change (not like what you have).-Failing transmission torque converter and/or clutches.-Failing TCU.-TPS out of adjustment.-Faulty wheel sensor and associated speed sensors.-Faulty TCS Control Unit.-Faulty wiring.
Depending on the situations given, most of the above causes can be ruled out. I see you didnt want an explanation of how to fix it, so I'll leave you here. Thanks. Hope this helps you.
