Traction Control Relay Location
mzarkowsky
Car: auto restoration, boating, woodworking
I am trying to locate the two relays that contol the Traction Control System. One of there purposes is to control the dash lights for "TCS Off" and "Slip". My lights come on but the slip light now comes on on a regular basis along with the TCS Off light which I manualy switch to disengage the system every time I get into the car. About four years ago the dealer replaced two relays (Part # 25230-89981) and everything was fine until a couple of weeks ago. When both lights are on the console switch for the traction control does now operate until the ignition key is turned off and the car restarted. I bought the two relays from Scottsdale Infiniti and now need to identify where they are located so I can change them and hope that fixes the problem. Anybody have any experience with what might be causing this or help with the relay location.
Rex
Car: None
Try searching for a post by rover3l in the Online Infiniti Mechanic forum. He has offerd aloty of info about this, but in short I think it's under the battery tray.
Search Results, I'm passive that way :).
jtesensky
Vendor
Car: 2005 Infiniti QX56
2002 Infiniti QX4
Here you go...
TCS Relay Location
