C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed Dec 28, 2005 11:36 am
Matt, I looked over the tire sizes you have and it's pretty close in front to rear tire speed differential to the OEM set-up(OEM is .970 and yours is .966). Since your front tires have some treadwear, yours may be a bit closer to .960, possibly lower. Not sure how much wiggle room the factory has built into this, but I would expect at least enough to account for uneven front to rear tire wear. The brakes in that of themselves should not be causing this problem. We can check it out this weekend when you come over...
