Traction Control -- G37s
BicycleConvert
Car: G37S
Is there a way to make the traction control less intrusive with out completely disabling? I find myself turning it off quite a bit, but wondering if there is another way to 'tone it down'
Ideas?
joe603
Car: 2014 Durango R/T
The G35 is the same way...
To my knowledge, you can't.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
There are two things you can do to "tone it down". One is proven, the other is more my opinion (which may be VERY flawed).
The first is to run slightly larger tires in the rear. This will widen your slip band slightly.
How? The rear and front wheels have a ratio and corresponding window that must be maintained in order to "satisfy" the traction control. If you make the traction control think that the rear wheels going slower than the front wheels (by using taller tires) then you have now widened the slip window, because you have the normal window of slip (say 3%) + the amount of "negative" slip that you have introduced with the larger tires. I wouldn't exceed 2% as this might cause some issues.
Here's where my opinion comes into play. After installing a grounding kit on my G, it seems like the VDC kicks in a little later and drops off a little sooner. So I can actually slip the rear a little without getting the SLIP and cut throttle.
Again, this is completely based on my impression. I may be totally off kilter here.
Jacko3
After starting my car, the next thing i do is turn VDC OFF--It is easy. Can't remember when i last drove with VDC ON---hate the intrusiveness--It makes me feel like I am crawling to my spider web/lair.
adren77
Car: 2004 G35 Laser Red Coupe 6MT
Sentientbydesign wrote:There are two things you can do to "tone it down". One is proven, the other is more my opinion (which may be VERY flawed).
This is proven? By whom?
Sentientbydesign
96 I30 - Sold
Me and physics! Go take it up with God if you don't like it
Jacko3
G_whizz
Car: 2010 G37 Coupe Sport
WIN!!
