Traction control and brake warning lights
carnifolks
Car: 2011 Infiniti FX35
2017 Infiniti Q70
2017 Q70 RWD 58k miles
My traction control and brake warning lights go on at the same time and then go away after 5 or 10 seconds. I haven't brought it in to the shop yet but am due for an oil change soon. Before I go in, would anyone know what the problem might be?
Thanks in advance.
JCT
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Check your brake fluid level. If it's at or below halfway between Min and Max, it's likely the fluid is sloshing when you turn.
carnifolks
2017 Infiniti Q70
Come to think of it, It seems to come on with acceleration or going up hills. Nice job VStar. will check in the morning. But would that also cause the traction control light?
VStar650CL
Technical Expert
Yep, and the ABS will have a "past" code in it for fluid level. That causes both lamps to light.
