Tracked the RB for the first time this weekend.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Ive ran with the KA before, but this is a different ball game. Front tires left much to be desired because it would understeer when the compound on the yokohamas i had would heat up tremendously, but straightline speed and otherwise high speed corners is where the car excels. Coolant temperature after a few laps went up to around 90-95 degrees celcius. Oil temp was around 250-260 degrees. So i was letting off for a lap or two to let it go back down to 85 coolant and 200 oil.
Straightaway speed, and the torque pulling me out of the corners, kept me in front of the Yellow Z06 vette, and quite a few of the porsche 911's.
Next month is, AVON A6 slicks, DOT 5 brake fluid, endless brake pads, and some brembo slotted rotors.
Silver Z06 was faasstF ck! Blew an intercooler pipe... Its hot outside! let me get out!Miata tried overdoing it to outrun me and ended up like this and almost getting hit by me.Got around it fine though. Theres probably more good ones, ill get em later.
CoupedUp
Car: 1993 Coupe
RAWR RAWR RAWR. Im a 2 forty.
turbot304
Car: 1989 240 silvia/skyline convertion
man, nice set up under the hood and love all of the picture posting to> especially the ones with you in front of the vets
JPsNissans
Car: 04' SE-R Spec V, 95' S14 240sx
You have a beautiful valve cover.
Shocker
Car: 89 240sxHB rb26/30
road coursing is soo fun.
looks like you had a good time.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
nice stuff
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
That looks so fun! The nearest road course to me is about 3 hours away and you have to go through some training on the course, so it is a huge hassle for me to even bother. Some people have all the luck
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Nice! Another RB 240 on the REAL track... keep it up!
blurrbosi
Car: 240's
That looks like a blast!!! Awsome pics man!
Darius
Just a side note...Your oil catch can is not hooked up to "catch" oil too well. Basically just setup as a stock PCV system minus the reroute to the intake. You really want to change that because the crank case is being pressurized under boost when the PCV valve is closed. Refer to the oil catch can threads that were floating around a few months ago.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Looks like a blast! Your car looks HOT man!!!
-Dan
Kansei240sx
Darius wrote:Just a side note...Your oil catch can is not hooked up to "catch" oil too well. Basically just setup as a stock PCV system minus the reroute to the intake. You really want to change that because the crank case is being pressurized under boost when the PCV valve is closed. Refer to the oil catch can threads that were floating around a few months ago.
Huh?
My Catch can does route back to the intake. Ill post pics later. That system isnt seeing boost whatsoever.
More pictures coming, btw, this is the track i was racing at.
http://www.hallettracing.net
Also, thanks Dan.
Kansei240sx
Bluefire
what kind of suspension are you running? diff?
-Bluefire
Kansei240sx
Modified KYB GR-2's( Beefed up i guess - Adjustable height, camber adjustment ) with R1 racing springs @ 300 lb spring rate.
Super Hicas VLSD.
Sky80
Car: '92 240sx Fastback
well i take it the new radiator setup that you did is holding up fine?
Kansei240sx
Yes, extremely well.
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
looks good more suspension STAT! is that halett? makes me wish i still lived in tulsa.
Modified by RB20DETodd at 7:02 AM 6/28/2007
Darius
Sorry my bad! It looked like both lines on your catch can went to the valve covers from that angle.
