93low240sx wrote:i ran that time without and intake on.
Ok, but that doesn't answer my other questions. I need to know those things to help you figure out why you're not running at least a 16.5. For example:
Excessive wheelspin=bad launch, slow ET, lower trap speed.
Compression leakdown=power loss
Plugged cat=more power loss, renders cat-back exhaust useless
Retarded timing=power loss
Plug gap too wide=power loss
Old plug wires=too much resistance, power loss
Not going to WOT=not running the car to it's full potential
Previously ran race gas=leaded fuel will plug the cat and foul oxygen sensors=power loss, efficiency loss
Do you see where I'm going with this? It's all in how the car is tuned and how it is driven. To help you, we need more information. Your transmission could be slipping as well. Have you checked that?
If you run w/o an intake, you have basically zero intake restriction, meaning that you should be even quicker, theoretically. Given that you had zero intake restriction, it leads me to think there is something else wrong. Mods are great, but if the car is not in a good state of tune, ie you have compression issues, mods are pointless and you need to address the other problems first.
