LA02MAX »
https://forums.nicoclub.com/la02max-u47165.html
Sat Sep 23, 2006 6:06 am
No, you didn't come off as a d!ck at all. However, I'm not sure I understand the first part of your post. Did you advance your timing to 20*? If so, are you looking to keep it that way? This is a good quote from ls1tech.com:
"Improving combustion efficiency allows timing to retard, which then allows for combustion events at a later stage of piston rise (crank angle closer to zero). This then results in reduced 'negative' work 'against' the combustion cycle and improves BMEP and HP.
In other words, if you stop making more power at 22 degrees of timing, there is absolutely no point in going to 28 or 32...."
just some food for thought...you can do whatever you want but I just wanted to inform you that after 17* you will se no improvement
Secondly, although the throttle position does affect ignition timing, it's not the only thing. Throttle position and engine speed are the two biggest factors affecting it (among MANY others). When you go above ~ 2300 RPMs, regardless of whether you're at WOT or not, the ECU will use the stock timing maps. Similarly, if you are at WOT <2300 rpms, your ECU will do the same thing. The only ways to change your timing throughout the rev-band is to either get a Technosquare ECU upgrade, get bigger injectors/raise fuel pressure and remove fuel via MAF conditioning, or get an E-manage Ultimate.
Ignition timing changes dramatically throughout the revband, so you can't really say "20* at WOT".
Look here:
I would think your timing would be closer to the 4th gen timing, as you have a 3.0, but I know your ECU does differ greatly from theirs, so it may be totally different. This is just showing how timing is affected throught the revband
Anyways, I'm sorry to hear about your track experience. What were the conditions like? Also, what tires are you running on, and what's your launch technique? I would definitely not go to the track right now down here in louisiana, because it's like 95* with 100% humidity, which would even make my car run in the 15's! haha.
Modified by LA02MAX at 5:32 PM 9/23/2006
