^^^ He wont... I have an s14 auto and have a decent amount of mods more then you. I have never gotten a 15.699 and a best of 15.70x at 65f. I mustered a 15.702 a half-year prior with about the same mods as I have currently (few mods where modded as well as some other things) but it was 45f out... Also I swapped from 205' to 225' rubber so I had to have gotten faster as my times dipped after that, plus Im pulling the 15.7 at 20f warmer... I also run about 87 - 90 mph traps...
Headders wont shave .3 Im sorry to say, especially in an auto. I didnt and I would have to say that with an auto, I gained very little from stock mani, precat, test pipe (had 2 cats) N1, to stock mani gutted pre and test pipe, to HS header secondary cat and N1... I noticed no speed increase with a test pipe and headder so I left it off, and run the single cat to save my ears.. With a manual I might have gotten more / something, but if I gained .05 seconds with it on I saw it as none for the god awfull honda sound it emited...
I dont mean to sound rude but its just not there. You also have to think about the transmission as it ages becomes even less efficient. Its like adding parts makes up for the loss of efficiency at times. Or the more power you put down on an aging transmission the more it slips, and the more you loose. I meticulously change the fluid with mobil1 synth atf as well... With a fresh transmission im sure I could be a bit faster, much in a the way a fresh clutch vs an aging one will. I have 111k on mine and have owned maintained it with mobil1 since 28k in 99'.
I may run again soon, but I lost my taste for the strip the second I punted a cone at the auto-x... That was back in sept... Ive remodded some things like the ram air (much better flow but its all internal smoothing
), and soon to be cams again so I may go back wed or so...
My mods:EI ram-air intake coupled with a jwt popcharger (see cold air post)Thermally wrapped HS 3" intake tube91' or 240-248 (soon to be 248-232 friday) cams.Dual Altima electric fans (one of my fav auto mods as it gave me .1-.2 and +2-3mpG avg)Accel wires (cheaper then oem as I needed new ones and less resistance)HS headderSingle turtle (cat, 2.5" TP netted nothing in current state)Apexi N1base timing of 22 - 24 depending on conditionsTB coolant lines removedEGR disconnectedupgraded grounds (if you call that a mod)
Then there is the suspension which doesnt really help but still:Koni yellows / progress 1.5" springsES poly LCA / Tension rod bushingswhiteline 29mm / 22mm swaysTanabe / Cusco, F / R STBEI tension rod bracket brace (replicated nismo power brace)EI subframe spacers
EI - Enigmatic Industries, or custom / rigged
Probably something else but oh well..
