x2Carl H wrote:do you have a ps cooler on the system?might have boiled the fluid over if not.
WTF?HxC_Nismo wrote:man ive never seen that happen before and ive been an auto mechanic for 7 years now. i would clean all your sensors that possibly got fluid on it and clean out your intercooler, and then run some seafoam through the intake to clean the rest, and see if that helps. and also you might want to upgrade to an better p/s cooler and a new reservoir.
LOL grouchy old man post of the weekAZhitman wrote:
WTF?
No offense, man, but if you've never seen someone boil over their PS reservoir, you've never been to a track event.
I do it every time I do a track day.
The PS fluid reservoir cap is NOT a "sealed" unit. It's not brake fluid, it can breathe.
Also, "clean out your intercooler"? Dude. He got some PS fluid on his air filter. He didn't submerge it.
To the OP: Your engine did not "ingest" PS fluid. Relax. Seriously.
Clean your engine bay with degreaser. Flush your PS fluid, maybe add a PS fluid cooler, and put a sock over the reservoir next time you do a track event.
Your overheating issue is SEPERATE. You have a cooling system problem. Check compression, look for oil in the coolant / coolant in the oil. Change all fluids, maintain your cooling system properly, and do a compression test.
He didnt even make any referance to his turbo, how do you know hes still not running the factory turbo or another small T3 turbo?l0nestar wrote:309 @ 17.5 psi sounds.. poor.. Sounds like your PS reservoir / cooler is the least of your worries.
That is most likely your problem right there. I'm not certain on the s13s, but stock KA temp gauge on s14 with RB coolant sensor makes the gauge read artificially high. Way high. I'm talking normal operating temperature ~180 F is already at the H. I know because I still run the RB coolant sender with s14 factory gauge, but I have an aftermarket gauge too.Vkoslak wrote:I should also mention, I'm using RB coolant sensor and stock KA temp gauge.I need to put in a real temp gauge.
and this is why you dont take track cars to repair shops hahaHxC_Nismo wrote:man ive never seen that happen before and ive been an auto mechanic for 7 years now. i would clean all your sensors that possibly got fluid on it and clean out your intercooler, and then run some seafoam through the intake to clean the rest, and see if that helps. and also you might want to upgrade to an better p/s cooler and a new reservoir.
You're welcome, Mr. Late-To-The-Party.Joe wrote:its called boilover as was already mentioned. not a bad seal. its VERY common on tracked cars.
shut up old man i was in the garage getting my car ready because unlike your ghey a** ill actually be driving on saturday.AZhitman wrote:
dude i never heard of anyones engine getting power steering fluid into the engine thru the intake, IVE HEARD OF P/S FLUID BOILING OVER before. if you read my full post you would see that i recommended him to upgrade to a better p/s cooler. and if his engine did somehow suck alot of power steering fluid i was just recommended what to clean as if your turbo oil seals go bad, or if you have alot of blow by and and oil gets into the intake. thats where the oil usually puddles up at.AZhitman wrote:
WTF?
