spitalul2bad »
https://forums.nicoclub.com/spitalul2bad-u98702.html
Sun Mar 01, 2009 6:26 am
Hi.
I booked a track day on April 1st and am looking into getting some new rubber. I can't really afford new wheels (rims for some) right now, but I could buy a set of Hoosier R6/A6 or Toyo R888s, front and rear. So I would be putting them on the OEM wheel. I have the Touring v2 18" wheels on a 35 anniversary model (not sure, it's the REV-UP engine anyway) Roadster 6MT (brembo brakes, leather, so on).
My question is, would 245/40/R18 fronts and 275/35/R18 rears fit on the OEM wheel? The OEM wheel sizes are 18x8 front and 18x8.5 rear.
Finally, when I save up enough money, I think I'm going to go with the Volk CE28N 18" wheels. I used the following InjectedPerformance Blog listing to decide. The Volk CE28N wheels are the lightest 18" that I could find.
Volk CE28N 18×9.5: 16.76 lbs (7.60 kg)Volk CE28N 18×10.5: 16.53 lbs (7.50 kg)Volk CE28N 19×9.5: 20.61 lbs (9.35 kg)Volk CE28N 19×10.5: 20.50 lbs (9.30 kg)
Volk RE30 18×9.5: 17.86 lbs (8.10 kg)Volk RE30 18×10.5: 18.85 lbs (8.55 kg)Volk RE30 19×9.0: 19.84 lbs (9.00 kg)Volk RE30 19×10.0: 20.39 lbs (9.25 kg)Volk RE30 19×11.0: 21.38 lbs (9.70 kg)
Volk TE37 18×9.5: 18.65 lbs (8.45 kg)Volk TE37 18×10.5: 19.40 lbs (8.80 kg)Volk TE37 19×9.5: 20.94 lbs (9.50 kg)Volk TE37 19×10.5: 21.82 lbs (9.90 kg)
Volk SF Challenge 19×9.5: 26.79 lbs (12.15 kg)Volk SF Challenge 19×10.5: 27.67 lbs (12.55 kg)
Volk GTS 19×9.5: 26.79 lbs (12.15 kg)Volk GTS 19×10.5: 27.67 lbs (12.55 kg)
Volk GTV 19×9.5: 26.57 lbs (12.05 kg)Volk GTV 19×10.5: 27.45 lbs (12.45 kg)
Nismo LM GT4 18×9.5: 18.51 lbs (8.40 kg)
350Z Stock weights:Touring v1 18×8.0: 26.56 lbs (12.05 kg)Track v1 18×8.0: 18.19 lbs (8.25 kg)Track v1 18×8.5: 18.62 lbs (8.45 kg)Touring v2 18×8.0: 24.40 lbs (11.05 kg)Touring v2 18×8.5: 25.80 lbs (11.70 kg)Track v2 18×9.0: 21.25 lbs (9.65 kg)Track v2 19×10.0: 29.50 lbs (13.40 kg)
370Z Stock weights:Sport 19×9.0: 23.20 lbs (10.52 kg)Sport 19×10.0: 23.80 lbs (10.80 kg)
