This is pretty basic for a question, but it seems it hasn't been asked before:
I never had a TPS wired into my wiring harness when I had my swap harness converted from KA24 to RB25, I have the plug that should have been used in the harness for my TPS, but no wires whatsoever to lead to the TPS.
HOWEVER!!!!
I do have wires at the ECU (pin 38 and 48, for sensor) for a TPS, so I am wondering if I can run the TPS signals and ground wire (grounding it at the chassis) and have a functioning TPS?
It seems kind of silly to not have a TPS, even though the engine has ran significantly better than expected without one.
(my reference:
http://www.gweeds.net/carpage2...t.pdf)
