s13rb25det »
https://forums.nicoclub.com/s13rb25det-u27134.html
Mon Oct 03, 2005 7:23 pm
all right so this is whats up, I changed my tps sensor and measured voltage and it is constanly at 5 volts! is this right? I was told that you should move it to were it is at .5 volts at idle and should go up to 5 volts as the throttle is opened this new tps sensor is at a constant 5 volts no matter which way I move it! (Im talking about the sensor not the throttle) if you guys have any info about this that would be cool!! thanks Roger Larson
