^Hey Boss I fixed your title, I was stumped as to just what you were talking about.
There are a few quick things I would like to add to your point there.
-If there is a P0507 stored in the engine computer this procedure
will not ever complete. The best advise is to immediately before the procedure is to be completed erase the self diagnosis results.
-Also the procedure will not complete if the timing has been manually altered, using the Nissan Consult.
-The vehicle must be above 170F (not specific just a good rule of thumb)
-All loads must be off. AC,radio, lights etc.
This procedure teaches the computer what the airflow and base throttle position are under ideal conditions anything that may alter that might cause the procedure not to complete. If the procedure starts but does not complete the Check Engine Light will most likely illuminate with a P0507 stored.
Good Luck.
