TPS test need help
ash32
hay there iv got a r32 with rb20det witch started idleing funny so did a ecu check witch came back with TPS problem so i did all the tests you can do on the TPS i also have a spare throttle body i check to match it up with the one on my engine
what i wonna know is when you test for signal voltage from ecu witch should be 5volt with key on but is this ment to be 5volt on both signal wires or just the signal supply , im getting 5volt on signal supply and the other signal wire reads between 3 and 4volt is this correct
any help be great
robbie2883
Car: 1998 RB25 Kouki
signal wire should read around 0.5 volts when idling and close to 4.7-5 volts at wide open throttle
ash32
im not getting signal wire to go from .5volt to 5volt witch im guess it means tps it shagged but im wonting to now if your ment to get voltage on both signal wires coming from ecu when unplugged with key on?
noodl35
My rb26 tps wires are black,white, red.
Black is ground
White is signal
Red is power
Red gets power from ecu at 5v ign on.
White should be 0.45v closed throttle and 4.5v wot ign on.
My issue is that i adjusted mt tps to be .47v closed. When i fully opened the throttle (wot), it reads 4.27v.
Think tps is bad?
Hope this info helps OP
ash32
is that with tps plugged in?
Carl H
vref is 5v, signal can vary all over the place but normal is considered 0.5-4.5v closed/wot.
voltages can vary greatly but as long as the tps responds in a liner manner it will be fine.
