guyaverage »
https://forums.nicoclub.com/guyaverage-u13673.html
Fri Dec 10, 2004 3:22 am
I had a similar situation about 3 weeks ago, idle would jump up and down really fast, and eventually stall. Have a helper start it up, and once it starts put some pressure on or wiggle the airflow meter connector. Once I did that my idle instantly stabilized and was smooth as silk, until I took pressure off the connector, then it would go crazy again. I pulled the connector off (there is a retaining clip), bent the male contacts (on the airflow meter) about a millimeter in opposite directions, then used needlenose pliers to slightly crimp the female connectors (in the plug). Gently reinstall it (be carefull not to bend the contacts worse when you are putting it back on) and start it up. I did this and its been perfect ever since.
