Kouks »
https://forums.nicoclub.com/kouks-u27952.html
Fri Feb 29, 2008 1:55 pm
the last part bolt on plug up and blah blah blah.
Does this happen when its cold only? For example, if you first crank it up after its been sitting awhile, motor not at operating temp, it does it. What about after it warms up to operating normal temp?
If it still does this then, then its not a cold start issue.
The diagnosis by "someone" IMo doesnt know about cars that much to just tell you that. A TPS is a potentiometer, meaning the tps gets a 5 volt reference signal sent to it from the ECM, then depending on where the throttle is, will determine the amount of resistance in the potentiometer, to determine voltage being sent back to the ECM to determine where your foot is at. Which is where a TPS gets grounded btw. ECM/ECU
TPS sensors are mechanical and prone to wear, generally where your foot is most frequently. you could describe it as a buck or trailer-hitch sensation while driving. Nothing which you cited.
Give me a better very thorough explanation of when it hapens when it doesnt, hot cold first starting up, then after it warms its fine blah blah blah.Then I might be able to help you..........
