Bad cable? might be sticking change it out.240240 wrote:ok so im sitting in traffic today and I move forward a little bit, take it out of gear to idle, and car just starts to rev really high, and I have a MINES ecu with no rev limiter (sux) anyways, I had to just cut the car off went it went past the 8 grand (240 Tach). Turned the car off then back on, did the same thing reved up really high. turned it off then on again and it was fine? I didnt seem like my petal was sticking
Any ideas?>
still! even if it is reading high thats a solid 5000+ actual RPM. no TPS problem will cause that. the engine cant physically get enough air without the throttle beig open.eh? wrote:Why won't it on a 240sx tach?. Mine disconnected went to 3k on a Calibrated tach. That's why i asked what it usually idles at.
That makes no sense...I've unplugged my tps and done everything imaginable with it and never had it change revs. How does the engine get to 5000 rpm w/o any extra air?Sil240 wrote:No I have actually had this problem with my KA SOHC, one of the TPS wires had come loosewhen i was drivingIt shot up on to the rev limiter, then i shut off the car and then started it again and it still did itThen i noticed one of the tps wires disconnected, put it back in place and never did it ever again
I don't know about your RB20 but on an RB25 if you unplug the TPS, it will drive the IACV open because the ecu has no reference for idle. But it won't go to 5k.goofynick6 wrote:
It is probably quite inaccurate by that point, but it should be 5333 rpms, it is 1.5X higher because it has 1.5x more cylinders than stock. You can adjust the blue potentiometer screw on the back on the tach to make it quite accurate though, just need another tach for reference.240240 wrote:By the way, 8000rpm on the 240 tach is really only 5000rpm?
