DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Tue Dec 07, 2004 9:36 pm
Often cars will have to relearn with the new sensor, so disconnect the battery for 24 hours to reset the computer. Drive it around when you're done, working the throttle back and forth from idle.
Good question though...why did you buy a new one?
The TPS is simply a variable resistor. Almost identical in function on most cars, fairly easy to troubleshoot with a DVOM.
