Bluefire »
https://forums.nicoclub.com/bluefire-u7784.html
Sat Jun 03, 2006 3:09 pm
Series 2 have to plugs for the throttle body one is the throttle position sensor and the other is throttle position switch? Series 1 only have the throttle position sensor.
As for the transmission there should be 3 plugs to 3 sensors, Neutral, Reverse, and Speed. If your using the KA lower harness you need to solder on the plugs from the RB lower harness so the plugs will mate up...
-BLuefire
