TPS removal?
s13point5
Car: 89 240sx
so i was trying to remove the TPS from my stock RB throttle body to put on my Q45 throttle body .(i hear the series 1 TPS can be used on the Q45 TB. someone correct me if im wrong). anyways i remove the two bolts holding it on and it wont come loose from the TB. it just rotates. what else do i have to loosen to get this thing off?
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
t should just pull off perhaps it could jsut be stuck.is there somethign wrong with the TPS on the Q45 throttle body , i mean why dont you just use that one..will save you having to adjust the new one with a volt meter.
