Yes, the problem seems backward from what it should be. When the engine is cold, the idle is at about 750rpm . As soon as it's warm, it idles at about 1700rpm.
The first thing I'll check id the airflow meter (since that's the simplest)
. Then I'll pull the check the idle valve and the aac. I've been intending to do that anyway.
UPDATE...When I pull the plug from the airflow sensor, the idle drops to around 500rpm. The voltage, when it's idling at 700rpm (per the tach) is 1.54 volts.:help
