TPS question
NISMO24096
What are the problems that are associated with running a auto TPS on a manual car....or is there any issues with doing this...my car seems to bog at full throttle and picks up at 5500 rpm...or does this sound more like a knock sensor problem...I know it has thrown the knock sensor code in the past... once again thanks for your input...
NISMO24096
So basicly just need to know if its ok to use the auto tps with a manual ecu...thanks in advance everyone.....
NISMO24096
So does anyone know what the voltage output on a auto tps is..is it the same as a manual one...thanks...
offroadbob
Car: 96 240sx, 84 720 4x4
Check out the FSM http://www.nicoclub.com/FSM/ I believe the auto and the 5speed tps's run in different voltage ranges I cant remember the part numbers i have one of both for a obdII I'll look and post the part numbers
mixeds14
Car: 240
i believe the auto tps has two plugs o it, to were the 5speed has one, th readings are different, auto: can check volt only when fully close and wot and 5speed close, partial,wot readings
NISMO24096
so from what I can gather I need to put the manual one on the car. that might help the bogging im getting at full throttle...and just the overall performance of the car...I hope...thanks for the input and if anyone else has anything to add please do....
offroadbob
both the auto and the 5 speed tps have two plugs on them for obdII cars 96+ the voltage ranges are just different. check the FSM for refrence!!!!
NISMO24096
The car is OBD1 and only the auto has the two plugs...I might just switch them out this weekend unless someone thinks there is no difference between the voltage on them....
