tps problems in 240sx
mr.silvias13
Car: Nissan 240sx
Ok i have a high idle problem with my ka24de. It idle high as 1800rpm and also when i do a stop my car died. Sence i nned to smog my car i was wander if it will affect on the smog and if it does how would affected.
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
mr.silvias13 wrote:Ok i have a high idle problem with my ka24de. It idle high as 1800rpm and also when i do a stop my car died. Sence i nned to smog my car i was wander if it will affect on the smog and if it does how would affected.
You may have an issue with the AICV (Air Idle Control Valve). You will most likely have an issue passing emissions, I'd definitely get this checked. Try adjusting the adjustment screw on the air idle control valve to see if your idle speed changes. Also, run through the factory service manual and perform some of their diagnostic checks to see what the root of the issue is. If you don't have a copy, you can find it here! http://www.nicoclub.com/archives/nissan ... nuals.html :biggrin: Good Luck!
mr.silvias13
Car: Nissan 240sx
I put a new AICV and even when i close or open the scree all the way the idle wont change at all. Any more ideas that can help me please.thanks
waxdnuggz
Car: 90 240sx hatch SOLD
91 240sx hatch SOLD
92 super sweet daily (freezing cold a.c., working ps and pw)
93 240sx hatch SOLD
94 240sx vert SOLD
Tps shouldn't affect it that much 1050+ over stock idle is huge. Check your distributor for correct timing and adjust your tps also you might have a leak in your intake manifold somewhere make sure you have all your bolts in that seperate the upper and lower. Did you buy the car like this or did one day it juat happened?
ezb57e
Unplug the IACV, maybe try tapping it lightly. The motor is getting air somewhere to run that fast. PCV hose off, cracked?
waxdnuggz
91 240sx hatch SOLD
93 240sx hatch SOLD
94 240sx vert SOLD
Did you replace the aicv with a brand new unit? If it was too big of a vacuum leak thw car wouldnt idle without you helping it. You have a sensor problem. Test them all there aren't very many of them. Your high idle could also be from an intake valve not closing all the way. Also make sure you dont have a clog in you aicv pipe from the intake. Take the tube off and feel if its pulling air it should be a pretty strong vacuum. If the tube is clogged or kinked then it causes the sensors to over compensate .
ezb57e
Is the throttle cable mis-adjusted?
Clogs/restrictions in the PCV system would reduce the available amount of air and lower the idle speed, not raise it.
