tps problem!!
mendez61414
Car: 240sx ka-t
ok change the tps on my ka-t and i try to adjust it.. when its cold it starts right up but dies out and crank but wont start nomore.. was runnin when i remove the old tps. help
Gabes13
Car: rb20det s13
What?
zach-Ka
Car: 1990 240sx (SR)
lolzAre you sure you adjusted it correctly?
vancouverbc
Car: 1991 240sx
does it run when tps disconnected? reset the computer. tps should read .44 volts when you back probe it.
mendez61414
Car: 240sx ka-t
nope i took the tps and the throttle tip thag come with the tps off my other 240 and it turns on but idle low like around 300 and 500 rpms anx when i try to raise the rpms it wont rev up.
Gabes13
Car: rb20det s13
You have to adjust it. I think Vancouverbc has a tutorial in his sig.
visser003
Car: 1991 Nissan 240sx Coupe
mendez61414
Car: 240sx ka-t
yea but nothin still dies. it was workin fine before i remove the old tps cuz it was ridin rough
