TPS problem
S13silviaboy
Car: 240sx
ok i think my TPS is bad. when i start the car and rev it, it revs but when its done revving it just dies. so i turned on the car and went and played with my TPS but the funny thing is that when my throttle plate is fully closed, the way its supposed to be, the car just shuts off like it not getting enough air???? so i played with the TPS and its a little better but still shuts off when the throttle plate is fully closed .
oh yea i have a s14 sr20det if that helps
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
You could test it. If its good then Try seting your idle screw higher.
duffman1278
Car: 89 240sx Hatch, the wildcats!
Test it with a multimeter, you should be at like .37V at closed throttle, and 4.00V at WOT.
