SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Mon Aug 16, 2004 10:11 pm
Yes, a six pronged plug is from an auto engine harness. You take the black wire off the 6 plug and splice it to the black wire on the TPS. You take the white wire and splice it to the white wire. You take the red and green wires from the 6 plug and splice them together into one wire and then splice those into the green wire with red stripe off the 3 wire manaul TPS. I have it set up that way (auto engine harness and manual TPS) and the SAFC2 picks up the voltage perfectly. But whenever I use an auto ECU it ignores the TPS signal, whenever I use a manual ECU it reads the TPS singal. Odd.
