USMCgetsome »
https://forums.nicoclub.com/usmcgetsome-u15451.html
Thu Nov 16, 2006 12:24 pm
Ok so now my idle is consistent drives great. Throttle plate has been moved to a more open position and tps was set accordingly. I hessitate when throttle is applied. I think it's the damn tps but not sure. It does not make the click when adjusted. Vacuum is at 15psi 850rpm. I open the throttle plate just a lil to make 20psi rpm is at 1000-1100. I'm going outside to go and read my damn tps voltages. Man i'm so close to have a 100% runnin motor.
Replaced so far. MAFdCASECUThose have solved alot of problems so far. This is the absolute last problem so far. Everything else is great. Pics will be posted later on tonight of throttle plate position.
