TPS help. where do the wires go?
krayton
My clip had no wires going to the TPS. So they probably got pulled. But im having some problems with my engine, so hopefully this will help.
I need to know where these wires exactly go. Theres 3 all together. My ECU pinout shows on pin 38 "Throttle Position Sensor sense" and another at pin 48 "Throttle Position Sensor." and maybe the 3rd is a ground? But hopefully someone who has this can tell me for sure. So I need to know where the top, middle and bottom goe.
This is a type 1 RB25DET from the R33. Any help would be great. Thanks
pic 1 pic 2
krayton
You sure? I have one plugged in.
krayton
I fixed the pic. Can you see if thats the right one? If your positive about this then i guess ill have to look for something else that could be causeing my problem.
krayton
Im having a hard bog at 3500 at full throttle. Either feels like no spark or no fuel. Like a cut off. Ive checked the IGN relay and fuel pump both ok. Any thoughts?
email me: [email protected]
JonPowell
Car: Cars, Music, My family
Sounds liek possibly a boost leak, double check all your intake connections. I had the same problem between 2500 and 3000 on mine.
I am looking through all my old pictures for you to try to find what wires those should be. There should be 3 in the harness for the grey connector right next to it they are in the same loom and I will try to get you an order to connect them to the TPS.
Good luck!
