tps harness question…
DevZX
Car: 1990 300zx twin turbo
1995 miata mx-5
1990 miata mx-5
Hey guys so my cars been running like crap and i herd if you remove the front tps harness while idling it should run worse, well i removed it and nothing changed. It is very corroded and its falling apart so i ordered a new one. But the problem is there are only two wires going into the harness not three… is it supposed to only have only 2? when connected its the bottom wire thats missing. Thanks
DevZX
1995 miata mx-5
1990 miata mx-5
sorry let me clarify, the OLD harness only has two wires in it the other wire is missing.
DevZX
1995 miata mx-5
1990 miata mx-5
nevermind.... lol...
nexus08
Car: 1990 300ZX NA
Glad we could help. :)
ThisIsSparTTa
Car: 91 300ZX TT 2+0
So, there's 2 connectors into the TPS, one is a simple state for the switch, used for fail-safe operation and some other side tasks, it reads: closed, open or WOT. The second is an analog voltage reading of the switch position, which scales to how far the throttle has been opened.
The TPS supports the 3 states, but Nissan only ever decided to read open and closed, not WOT. On my 1991 original harness, the connector only had 2 wires coming into it for those 2 states. However, that connector got messed up, and I got a used one from a friend, it was possibly a 1990 (don't remember). Anyways, that connector had all 3 wires running into it. I just double checked which one was for WOT and didn't wire it up.
http://z32.wikispaces.com/Throttle+Position+Sensor
emiliog2276
Car: 1990 300zx 2+2 NA
2002 Nissan Sentra GXE
To add another question to the post. Does anyone know if there is any difference between the non turbo version of the tps being sold. The is one for the years 90-93 and another from 94-95.
nissanfreak12
Car: 92 300zx 2+2 TT
TT and NA have the same TPS. Interchangeable. I also believe the 94-95 is the same, but do not quote me on that.
emiliog2276
nissanfreak12 wrote:TT and NA have the same TPS. Interchangeable. I also believe the 94-95 is the same, but do not quote me on that.
I was just wondering since CZP sells two different ones and the price difference is quite alot.
http://www.conceptzperformance.com/Cart ... .45.12.195
Foosblood24
Car: 93 300ZX NA
It's all about the years right there. Easy. Just to make sure, give ConceptZ a call, but if the NA and TT are interchangeable, it should have changed between 93 and 94 for both.
emiliog2276
Z1 only caries one for all years
ThisIsSparTTa
They look different but function the same as far as I know.
