Amybirds »
https://forums.nicoclub.com/amybirds-u43849.html
Mon Sep 25, 2006 9:10 am
Hello again,
Our 94 Q45 is acting up again -- The A/T error code says it's the Throttle Position Sensor but I'm going to do the FSM diagnostic to double check.
In the meantime, I'm hoping to clarify something:Are the two screws that hold on the TPS the two screws that I don't want to turn without a Consult to reset them? If that is the case, how do I go about replacing the TPS here at home without messing other things up?
Thanks!
For anyone that wants more details on the new issue: It's a 94 Q45, recently replaced the MAF (used) and the ECU (used) as well as all the belts and the battery. Things seemed to be going well (other than occasional Low Battery errors only when sitting at idle, but I think that' my alternator slowly dying and I don't have money to fix that right now).
Saturday, I drove it about 3 miles with no problems but then just as I got on the freeway, the RPMS would drop down super fast for a half second, then come back up, over and over till i had to pull over. I tried to get back going again a few times with the same results. So I sat there long enough to call my husband and AAA and then tried again (car still in drive the whole time, and idling solidly around 1000rpm when stopped) and the car worked fine but seemed to be in failsafe mode. Drove it about 20 miles to get it back home with seemingly no issues. Next time I got in the car it gave me a TRANSMISSION MALFUNCTION error, which went away. We checked the A/T codes, which said it was the Throttle Position Sensor, but then the second time we checked there were no codes and it said OK. Drove the car fine on Sunday for short errands. Husband got in car to commute to work today, car worked fine for about 25 miles, then it started acting like something was holding it back then acting normally, etc. Then it started having the RPM drops like I had experienced. And then, it started working fine again. Once again we have the A/T error code 3: Throttle Position Sensor
So, like I said above, I'm going to check out the TPS more, but if I need to replace the TPS, what do I need to know?
Thanks!!!-Amy
