wild_maxx »
https://forums.nicoclub.com/wild-maxx-u17600.html
Wed May 04, 2005 1:22 pm
ok today i have been working with my tps setting. i put a new tps on a few months ago and i didnt do it correctly the first time so i want to make sure i do it correct this time. first, i put on the new tps and put the screws in the top and bottom but left then loose, then pluged it all in and started the car and let it idle until it was up to full operating temperature. shut off car then probed into middle wire of large tps plug (not one directly connected to tps unit) and rotated the tps until i got a reading of .44 then tightened down holding screws. second i took a reading at WOT and got 3.54, is this the correct method to caliberate the tps? Am i using the correct volt setting to do measurments?
closed throttle
WOT
