DrifterProdigy85 »
https://forums.nicoclub.com/drifterprodigy85-u30257.html
Wed Sep 02, 2009 12:14 pm
Ive been having an oddball miss with my car. Ive checked all the spark, fuel, and timing related stuff. Now im onto electronics. I just installed an AVCR and its showing my throttle percent flucuating at 3.0-4.0% at idle. TPS is set to .45 Volts. Im guessing the TPS is bad but i wanna check with you guys to make sure. Also when checking the voltage, it is very irratic going from .38 to .52 volts. And when my electric fans kick on the voltage drops. This makes me think its an electrical issue. Everything is grounded properly to the engine and to the firewall. Would a bad alternator or battery cause this?
