thegary »
https://forums.nicoclub.com/thegary-u11219.html
Fri May 21, 2004 4:44 am
Hi there everyone. I have been for some time now trying to get my car running more smoothly. 91 240SX HICAS. Here is what i have replaced.
1. Seafoam (gas, oil and intake)2. new O2 sensor3. removed AIV4. New plugs and wire5. New cap and rotor6. cleaned throttle body7. new feul filter8. replaced AICV (acc) EXPENSIVE ONE!
Replacing the AICV fixed my idle dropping off to nothing and almost stalling.
When i try to set my idle, I disconnect the TPS and then race the engine a few times letting it fall to a idle position, but i cannot get it to come down to 650. The lowest i can get is about 1100. When i plug the TPS back in the idle is about 800-900. Any thoughts on how i can get the idle set properly? I have been doing all of this to improve gas milage and also to fix the fact that i have to press the gas pedal to start the car. The odd time it will start first turn, but thats about 1 out of every 20 starts. Also my power seems quite good when the engine is cooler, but i have noticed with the warmer wheather, when its about 15cel. out, then engine when warm is lacking power. Any thoughts.
Thanks ......thegary
