Stadsport »
https://forums.nicoclub.com/stadsport-u158692.html
Fri Feb 04, 2011 1:34 am
It means "Closed." Like I said, the TPS is two separate devices in one. The pigtail coming out of the device with the oval connector is for the Throttle Position Sensor--that's what gives you the variable voltage reading. Obviously that's working fine, which is all dandy. The three-pin connector at the front of the TPS is for the Hard Idle Switch. It's literally an on/off switch that, when the throttle is closed, turns "ON" to tell the ECU that the throttle is closed and it needs to idle.
When you're adjusting (rotating) the TPS, there's a "sweet spot" where the Throttle Position Sensor will read between .4 and .5v while at the same time the hard idle switch turns ON. When the TPS goes bad, a lot of times you won't be able to get the Hard Idle Switch to turn on unless you crank the Throttle Position Sensor down to like .2 or .3v, which is obviously too low to be within range.
The Hard Idle Switch consists of two metal "fingers" that push together when the TPS is closed all the way. Over the years, the spring material they're made out of gets tired and they won't make a solid connection. This is why you can usually get the Hard Idle Switch to turn on when you crank the TPS too low, because the more you turn it, the "tighter" you're squeezing the fingers together. You can actually take the TPS and clean/bend the Hard Idle Switch "fingers," but it's kind of tough to get them "calibrated" right, so you're probably better off just replacing it. Fwiw, they're all the same (other than the 96+). There's like 4 different models, but the only differences are the lengths of the pigtails, and some have a Wide Open Throttle Switch... which our cars don't even use.
Hope this helps.
