TPS: 1.16kohms when released....8.5 kohms depressed...is it bad?
johna_99_99
Car: 1992 nissan 240sx
the fsm says it should be approximately 2kohms when released and about 10kohms when depressed.....is the tps garbage.....i have been having issues concerning tps...thanks
benemorius
Car: s13, s13, eg, e36
When you say released and depressed are you talking about the gas pedal? If so, then it sounds like the TPS just needs to be readjusted. It has two screws. Just loosen them and rotate the TPS as necessary.
EDIT:
zerothread?id=114106
If the meter you're using is digital, you'll need to give it a second to autorange and settle on a reading before it gives you anything useful. If you mean it read high for a split second, that's normal.
Modified by benemorius at 7:52 PM 4/29/2005
