TexasMadrone »
https://forums.nicoclub.com/texasmadrone-u74360.html
Sat Sep 27, 2008 4:48 pm
I also have a '03 M45. As I understand it when I bought mine, I was told that only the four "on the ground wheels" had TPMS. The system only can read four (and unfortunately doesn't say which location), and if you had a flat, only three would still be listing useful flat warnings. Mounting the spare would not change the listing back to four "on the ground Wheels", since no TPMS is in the spare now on the ground. It would still be reading the spare now in your trunk. Once you fix and reinstall the flat to "on the ground", you would be reading rolling wheels again. If you added a TPMS to the spare, the system would not know which was rolling or which was the spare! If anyone knows this to be incorrect, please chime in! You TPMS on the '03 M45 will reset once you inflat to over 27 PSI and it rolls for a few miles. At least mine does.
