TPMS Sensor Replacement 09 Altima
General discussion area for the L32-chassis Altima
npolite
Hi Everyone,
I am getting the TPMS light which flashes and then stays on after a minute. I have to say I am surprised they have lasted this long. I have been researching this and I believe they need to be reprogrammed and there is a procedure in an older post on how to do this. I'd like to know if those Youtube videos which show to use a block of wood and a jack to pop the bead will work? I know there is also a tool which you can use an impact with but that seems if you don't get it just right that you could damage your rim. I can try to call around but unless I go into the city I doubt anyone around my area will do it on the cheap.
My other option might be to get a TPMS set and reader from AliExpress for the short term until I am ready to replace the tires next year. Also to confirm, I believe the OEM sensors are SCHRADER 29166 Programmed; Adjustable Metal Valve (Clamp-In). Is this correct? I would order them from RockAuto.
Thanks,
Nick
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The blinking means there's a malfunction in the system other than a low tire. There will be codes in the BCM for exactly what the problem is, but you need a code reader that's TPMS-capable. However, on a car that old, the issue is almost certainly dead batteries in one or more of the sensors. Reprogramming won't help that.
npolite
Sorry I may have misspoken, I was referring to after I replace the sensors that they need to be re-programmed (not auto programmed).
Also does the 2x4 with the car jack method work or will that damage the tire?
VStar650CL
Technical Expert
You only need to break the top bead to replace a sensor, there's no need to completely separate the tire from the rim. So yes, there are a number of DIY methods to bust a bead and that's a common one which works fine.
npolite
Thanks as always for your help.
VStar650CL
Technical Expert
:dblthumb:
Return to “4th Generation Altima Sedan (2007-2012)”
