TPMS replacement?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
chrisz
Car: 2005 G35x
Hi all,
Tried searching but didn't find anything concrete. My 2005's tire warning is going off about 15 minutes into a drive each time. I think perhaps the tire pressure sensors need to be replaced (as its now an 8 year old car), or maybe the batteries replaced (if batteries can be replaced). Any advice on what can be done to retain the TPMS functionality?
BTW, the tires are fine and holding pressure as they should.
Thanks,
Chris...
telcoman
I had a similar problem not long after I purchased my 2012 G37S
Long story but the problem was finally traced to an I Phone charger. Replaced the charger problem solved.
If you have any after market stuff in your vehicle disconnect it & see what happens.
Telcoman
chrisz
Car: 2005 G35x
Thanks for the suggestion. I've did some more searching and realized that my sensors are now 8 years old, hence the batteries are likely used up. So I had all four sensors replaced, problem solved.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
