EXceptional wrote:So right at 16 miles, the light turns off???
What happens when you remove one of the TPMS sensors from the car (as in switching a wheel): The first time you drive after removing the wheel, the TPMS light will come on after you drive about 24 kms (16miles?). Subsequently, every time you start the car the TPMS light will flash a few times and stay on until you either re-install the original wheel or re-index the system with a handheld programmer (like the one Kal-Tire uses). If the light came on because one of the tires was low, it will reset as soon as you restart the car after re-inflating the tire. The sensor alarms when a tire is a few PSIs lower than the rest of the wheels.
When I swapped the winter wheels for the summer ones, the tire shop plugged in their handheld device and re-indexed the TPMS system.
If you think this is complicated, consider my FX35: The TPMS not only alarm on low pressure but also display tire pressure in either PSI or KPA. When I rotate the wheels (front to back), the tire shop has to reprogram the TPMS according to their new positions.
