If you have two different set of wheels with two different set of tpms, then yes, you will need to recalibrate it when ever you change your wheels. Remember, tpms works off of radio frequency. Each set has their own which needs to be synchronize to the receiver.Sacky2.5 wrote:suppose i take off my wheels, and buy new wheels with new nissan tpms sensors to install on teh aftermarket rims. i take the aftermarket wheels to my dealer and they calibrate it, etc. Now if i decide at any point to switch to my stock wheels (ie during the winter), would i need to re-calibrate those as well? or can i just swap them whenever i feel like it at that point?
I was told at the dealership that the receiver/ control module is inside the transmission ( ), so I don't know if that is true. It would be stupid if the system tripped from rotating the tires...adidas2go wrote:...I was told by the STILLEN tire specialists that the TPMS control module looks for each signal at that specific spot...
How are the sensors installed? So, should I have my tires and wheels shipped unmounted?dangeris wrote:I'll answer the question sequentially:
1. no you don't have to buy a new receiver. I would though buy them from nissan as TPMS are particular to the vehicle.
2. Depends. My dealership said that they would only charge me $25 to calibrate. You'll need to call and find out.
3. Yes, you can use the stock tpms on the new wheels. no calibration required if you go that route. They are easily removed. Just have the shop who ever is mounting your new wheels to have them take the tpms off of the old wheel.
Good luck man!
