TPMS Not Working after Tire rotation, 2 months ago.
cji4130
Car: 2006 M35x
as the title describes, ive searched the forum for others experience with there tire pressure monitors not working after a tire rotation, all ended saying that theres began to work after a couple hundred miles. my tires were rotated almost 2 months ago and are still not working(just ** for all four corners) they all worked flawlessly before i had them rotated...... :mad: :mad: :mad: :mad: :mad: :mad: :mad: :mad: WTF?!?!?!?!?!?!?!?!??!?!?! this was one of the favorite features on my M.
atlM35
Do you ever drive for long periods of time?
If not, you might want to plan a short road trip whenever you have some free time.
They usually require the car to be moving constantly for a certain number of miles before they register.
If that's not the case for you, you might need to find someone with a CONSULT tool to reset the learning mode.
Twizz
Car: 2007 M35X - Stillen exhaust, Injen CAI, dropped on Espelir springs, Morimoto 3K Hid Fogs, Morimoto 6K low beams, Full interior and exterior LEDs, air horn, 35% tint all around(45% on the windshield)
this happened to me too. I had to take my car right back to them and told them what they did
cruzad3r
Car: 2006 Infiniti M35x fully loaded
drive on the highway for about 10-15 mins at around 65mph and it should come back. are you 100% certain these tpms worked before the rotation?
cji4130
Car: 2006 M35x
cruzad3r wrote:drive on the highway for about 10-15 mins at around 65mph and it should come back. are you 100% certain these tpms worked before the rotation?
lol, unfortunatly yes, im 100% certain they worked before the tire rotation, as i used them every time i drove the car. since ive had the rotation ive definitely been on the highway at over 65 for at least 25 minutes. i guess ill have to see the dealer about this....grrrr :mad: :tisk: :tisk:
cji4130
Car: 2006 M35x
atlM35 wrote:Do you ever drive for long periods of time?
i think i might have a consult tool in my garage, do you mean the device that plugs into the slot under the steering wheel?
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
If you move them they need to be reprogramed right? when I got my 20" the tire shop used a some tool to reset
cruzad3r
did you rotate front to back or side to side? i've rotated my tires multiple times front to back and the TPMS always come back. Even when i had my tires swapped at the shop, the TPMS also came back without any resetting procedure.
It is possible that your TPMS took a dump on you :) i hope not but you never know. What's your mileage and year?
atlM35
Some tire shops will come around to each wheel with their wireless device and reset each tpms at no charge.
I would call around in your area to see if any are willing to do that.
gbaker2
Car: 2001 I-30T, 2007 M35X
I just had four new tires put on and an alignment and only my front left side TPMS worked. I had to run the car at 70 miles an hour for at least 15 minutes and they all cam on. The service manual says you only need to go 40 miles per hour.
szh
Car: 2018 Tesla Model 3.
cji4130 wrote:i think i might have a consult tool in my garage, do you mean the device that plugs into the slot under the steering wheel?
Unfortunately, the Nissan CONSULT is a lot more complex and different from a typical OBD-II scan tool.
You probably need to see the dealer for this. Or take it to the place that rotated the tires - if it was a tire dealer, many of them now carry the reset tools.
Z
