TPMS Light
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
fax1
Car: Infiniti EX35 AWD Journey
Vehicles battery for some reason (still haven't figured out why) was almost dead and did not have enough to power to start the engine, this was 3 days ago. immediately jump started the vehicle and noticed the TPMS light was flashing and then was on steady. Tire pressures were all within specs. Light was not on prior to the dead battery. Vehicle has been driven over 150 miles as of today, tire pressures are still within specs and the lite is still on. Any ideas?
Thank you
NJGuy
Car: 2008 Infiniti EX35 Journey AWD
This was addressed in a recent thread. See the following link: reset-help-after-dead-battery-t593872.html
You may also want to think about either replacing the battery or getting to the bottom of what's causing it to run down. Otherwise, the TPMS issue will probably resurface.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
