BBISHOPPCM »
https://forums.nicoclub.com/bbishoppcm-u54071.html
Sat Sep 08, 2007 6:18 pm
I may be wrong, but since the TPMS is factory-installed safety equipment, it is required to be functional in the same sense that the airbag system must be functional in order for the vehicle to pass inspection. In the case of wheel swapping, I'm not sure what they would require you to do... but if your vehicle is stock, and under warranty, it is your right to get the situation taken care of. Disabling the system will only reduce the resale value of your car, and you will lose a valuable tool. Did your system outright fail, or is it giving legitimate low pressure indications? my TPMS system saved me... TWICE! The light came on just as I was pulling out of my driveway one morning, so I checked the pressure... it was just a bit low. Turns out, I had a nail in the tire. Had I not known the pressure was low, I would've run the risk of ruining a perfectly good tire by driving underinflated, getting into an accident on the highway, or worse. This happed a month later, same tire, different nail. Disabling the system is no better than putting electrical tape over an engine light on a car that is still under warranty. There is a problem, and they must fix it. Your one-year warranty is almost up, and since this is not the first failure of the system, they MUST fix it.
