Goon »
https://forums.nicoclub.com/goon-u75313.html
Sun Apr 12, 2009 5:39 pm
So, Newport, RI is going through heavy construction and ended up getting a 3/4" pyramid/arrowhead rock in my right passenger. that pierce through the rubber.
I took it to get it examined and brought new stocks. Can't change all four tires at the moment, but the question is about the TPMS.
Is it even possible for a technician to fix the valve behind the steam is leaking supposedly after the addition of lubricants to view the bubbling and fizzing.
Because unscrewing the stem would rotate the TPMS sensor and damage/break it? Is there an alternative to fixing this?
Somehow, they did put on new plastic caps and I couldn't hear the valve leak at all! But maybe it'll change tomorrow morning when it becomes partially deflated...
Any help would be grateful!
