I am running the tires 3psi lower to try and curb the issue of wearing the center of the tread out before the outer edges.RED_DET wrote:I would recommend running 38-40psi cold tire pressure. There will be less than 5% difference in hot tire pressure and will allow the tires to last longer. Just food for thought.
Be careful of running them too low, because you will get the opposite effect and wear out the edges because the tires will be cupped in the center. This can be a serious issue if a panic stop was necessary. Under heavy front braking, if there isn't enough air in the tires, they will cup and only the outer edges will contact the pavement. The center should wear some what more than the edges unless you have alignment issues. You contact patch is the center of the tire.awdjdmtalon wrote:
Wow, impressive sounds like fun.awdjdmtalon wrote:Thank you for the Info RED. Check out the Tire experiment that I am doing. It is stuck at the top of the threads.
I do have a fair bit of experience w/ tires. On top of being an Auto Tech for the last 7 yrs. I also raced SCCA autocross for 5 yrs. I know all about he affects of heat on tires. Esp. when it comes to inflation and grip.
I was an E stock regional champ one year and runner up another. The only real perfomance upgrade you can do in stock class is tires. And they must be a DOT R compound.
I was also runner up in D Street Prepaired another year.
I also Drag race import AWD. I did that for the last 4 yrs.
Absolutely. But I've run a different tire with the same results. There is some anecdotal evidence that the tire tread may be bowing out on an 8 inch wheel. I would imagine a tire with stiffer belts may be less susceptible to this effect, but a manufacturer may be less apt to use such a tire due to the extra weight and expense such a tire may cause, so long as performance is still good/acceptable. It wouldn't make good sense for a manufacture to specify 2 different wheel widths if both can fit the desired tires safely, unless there was some further benefit to be realized. But then this is merely speculation on my part...awdjdmtalon wrote:It does seem that the wheel is a bit on the narrow side for the 245, by what the tire manf. reccomend, but still w/in the range. And they also went to a different tire brand/ type when they move to the 8.5 wheel. So we are back at square one of speculation. The whole chicken or the egg question.
From what you have said, leads me to think that the tire is then over inflated. Infiniti may have had the tires set to a higher pressure to make the center of the tire taller. This way making less rubber on the road to help with rolling resistance to help fuel economy.C-Kwik wrote:
Problem I find with that statement is that with a tire to wheel match that is not pulling/pushing the sidewall in/out, the tread will likely be fairly flat under load at typical tire pressures. Its not like Infiniti is recommending higher than typical pressures used in other passenger cars.awdjdmtalon wrote:
Over inflation wears the center of the ties out. Under inflation wears out the outer edges.
This all rolls back to my tire pressure test that I am conducting.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
