Toyota pickup LSD in 240sx?
kozanatos
Is it possible to put a early 90's rear end in a 1990 240sx? has drum brakes but my friend has one laying around and said it would likely fit a nonlsd 240 i might purchase, is that possible? or is more information needed?-Thanks
Cone Junky
Car: S13 fastback
BMW e46 328i
Well the Toyota trucks use a live axle and the 240 has IRS, so it certainly is not a bolt-on operation. For all practical purposes, it won't work.
kozanatos
Thanks for the response. Sad, but okay. Was just an idea my friend threw out there
maryjane
spit up the cash for a vlsd, its a direct bolt in set up and youll love it!!
Ikera
Car: Nissan 240sx KA24E
maryjane wrote:spit up the cash for a vlsd, its a direct bolt in set up and youll love it!!
hay I read somewhere that in Canada 240sx comes with VLSD standard. I am in Canada and I just my 1990 240sx like a month ago. It has about 160,xxx miles on the transmission and differential. So I think even if my car does have VLSD it will never lock because I it's so old and needs to be drained and refilled??? can anyone confirm that?
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
LSDs use a different fluid from the gear oil that is in the differential housing, and unfortunately you can't change that fluid.
Ikera
well I have never checked if my differential will lock or not when I spin my tires... but I'll try to find out. Once I do I'll be sure to post here, it will be awesome if it will lock being as old as it is.
BrianV8
Car: 89 Skyline GTS
that would definatly be cool if you can pull it off.
