Toyosports Radiator(China) and Cooling experience
boki_s78
Hi ppl!
Is here anybody running his ca with that kind of Radiator which is made in china? I mean, the names are differrent, this one i have is 52mm thick and it has twin water channel core design.
What i would like to know is, how does it work combined with the ca water pump?
Is the pump good enough or should i get some external electric water pump?
float_6969
I've never heard of the water pump being and issue on the CA with any size radiator.
boost_boy
Looks like most cheap aftermarket aluminum radiators with toyosports spray painted on it. Like float says, no problems with CA water pumps and big radiators. If you must know, I use the same radiator less the toyosports logo on it and my car stays cool and normal.
boki_s78
Thx guys,
there is big discussion in german forums about the water pump and twin water channel core
thatswhy i asked here.
The logo is going to dissapear anyways ... was the cheapest on ebay.co.uk...if id buy it from usa ebay, the shipping cost would rip my a** and take too long couse i need it asap so thats fine :gapteeth:
DALAZ_68
Car: 90' 240sx CA18det
pretty sure my CXracing is the same freakin thing, and it works flawlessly...then again, my water was new also...lol
float_6969
I've always run stock radiators and never had an overheating problem. This isn't an SR ya know, LOL!
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
dont mean to thread jack but...what kind of fans are everybody using? I have a 14" CXRacing fan and I have to have a 15A fuse to keep it running..i feel like that is quite high IMO...
roast
Car: 1989 Silvia
sjbsuperman1425 wrote:dont mean to thread jack but...what kind of fans are everybody using? I have a 14" CXRacing fan and I have to have a 15A fuse to keep it running..i feel like that is quite high IMO...
Do you have a fan controller?
I'm running Altima fans and just got a auto-lite fan controller...
sjbsuperman1425
CA18DET
Yea i have an adjustable one which I am replacing with a non-adjustable one for simplicity..
boost_boy
X2 ebay 12" slim fans and they work flawlessly.
boost_boy
Don't your SDS have a fan controller on it?
sjbsuperman1425
CA18DET
Dee, what size fuses do you have? I feel like my amp draw from this fan overstresses my charging system and ultimately makes me lose power..
roast
Car: 1989 Silvia
boost_boy wrote:Don't your SDS have a fan controller on it?
I purchased the fan controller before buying the SDS... I'm deciding if I should marry the two and have the SDS trigger the auto-lite, use the auto-lite on its own, or just use the sds w/relay. The advantage of the auto-lite controller is when it triggers the fan's it turns the fans on from 0-60-100% where as the relay is 0-100%
