Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Mon Jun 30, 2008 7:58 am
obviusly the VG will out pull the 4 bangers. That said, none of these engines are powerhouses. How heavy a trailer do you plan to pull? I know the VG with the auto trans is rated at 5000 lbs, but it would really struggle with something that heavy, especially if there's any hills around. Half of that is probably more reasonable.
To add, the VG and 4 banger transmissions don't interchange. If you upgrade to a VG (I'd recommend a VG33 from a D22 truck, wiring harness and all), you'll need to swap in a V6 trans.
